Roborock S4 - Engineered to tackle complicated homes head on | Roborock Official Website
Roborock E35. Save $122 on Amazon.com, 19 Nov only!Learn more >
Roborock S4
Roborock S4
Tackle Complex Homes Head On
About S4
Navigating furniture is often the biggest challenge a robot vacuum faces. Roborock S4 takes that challenge head-on, combining Roborock’s advanced mapping and navigation with a revamped drivetrain that provides the power to free itself from obstacles. Intense cleaning abilities combine with remarkable intelligence to deliver a more thorough cleanup. And everything is placed inside an elegantly transparent shell that will blend beautifully into even the most carefully designed home.
Hard to Trap
Engineered to escape the areas where others would get stuck
Precision Laser Navigation
Comprehensive cleaning with high precision laser-guided navigation
Advanced App Control
Total control. Set virtual no-go zones, multi-day schedules, and more.
Deep Cleaning Power
Clean deeper with intense suction and adaptive brushes
High Endurance Cleanup
Vacuum vast spaces, with up to X hours of non-stop running
Built for the Escape
Use S4 in more complicated environments, thanks to a re-engineered drivetrain that makes it harder to trap.
Intelligent Home Navigation
Precision laser navigation ensures every spot of your floor is clean, and no spot is missed while treating walls and obstacles gently.
Total Control at Your Fingertips
Start and stop cleanups, set multiple schedules, use virtual walls, choose cleaning power and much more from an app.
  • Schedule Cleaning
  • Zone Cleaning
  • Virtual Walls
  • Virtual No-Go Zones
Built for a Deeper Clean
Intense suction, able to lift AA batteries, easily lifts dust off floors and pulls it out from inside carpets.
Goes where you want it
S4 automatically recognizes rooms, so you send it exactly where you want it.
Goes the Distance
Cleans non-stop for up to 150 minutes in Balanced mode, equivalent to almost 250sqm (2,700sqft).
Where to buy
