Roborock S6 & S6 Pure Robot Vacuum Cleaner | Roborock US Official Store
Roborock S6 and Roborock S6 Pure - Bring home smarter
Roborock s6 won iF design award 2019
Roborock s6 was awarded as one of the best robot vacuums by Android Central
Roborock S6 Series
Defeat dirt with Roborock S6 Series. Serious processing and precision laser navigation mean S6 and S6 Pure can map out your home then clean one room, many rooms, or your whole house with a few taps on your phone.
Roborock S6 Pure
S6 Pure
Roborock S6
S6
Adaptive routing handles a faster cleaning.
资源 18
Hyperforce suction pulls up every speck from deep inside carpets
Customize room cleaning sequences
Multi-level mapping support
Goes where you want it
S6 robots know your kitchen from your playroom, bedroom from living room1. Giving you the power to schedule cleans for a single room, multiple rooms, or entire floors, define specific cleaning sequences, and even set customized suction levels for every room across multiple floors. Housekeeping has never been this easy and smart.
Roborock S6 robots floorplan map for specific cleaning sequences
Smarter is faster
S6 robots always know exactly where they’re going. Using powerful 32-bit quad-core processors, the same kind found in smartphones, they calculate the most efficient route for cleaning each room.
Roborock S6 robots efficient route
Sense, avoid, and more
The massive Sensient sensor array with an accelerometer, odometer, infra-red cliff sensor, compass, and more give S6 robots 360° of sensing. They know where they are, can avoid stairs, find their way out of trouble spots, and keep your valuables safe.
Roborock S6 robots massive sensient sensor array
Reach More Floors
Multi-level Mapping systems use precision LiDAR scanning to recognize different levels of a home automatically4. Every floor can have independent No-go Zones, Invisible Walls, and No-mop Zones. And the current level is automatically recognized so you don’t need to open the Roborock app.
Roborock mapping system recognizes different levels of a home automatically
Drop invisible walls
Protect your valuables with virtual no-go zones or virtual walls, all from the app1. These can be as small as 0.4m (1.3ft) and as large as 10m (33ft). Use them to protect everything from small vases to entire rooms.
Roborock S6 robots virtual walls, 0.4m (1.3ft) - 10m (33ft)
Breathtaking suction
Powerful HyperForce suction pulls dirt and pet hair off wooden floors as easily as it dredges it up out of carpets. Created by a fan spinning at 15000rpm and channeled through advanced airflow systems, S6 series suction is effectively constant. That makes them possibly the best robot vacuums for picking up after your pets or kids.
Roborock S6 series effectively constant breathtaking suction
Comprehensive Voice Control
A few words are all it takes to get a cleaner home. Start a cleanup, send your Roborock robot to multiple rooms, control multiple robots, find a lost robot, change suction strength, and more. With Amazon Alexa support, cleaning up is now easier than ever.
Alex, ask roborock to resume
Alex, ask roborock to clean
Alex, ask roborock to dock
Roborock robot comprehensive voice control with Amazon Alexa support
Capture Allergens
The onboard E11-rated filter3 captures up to 95% of allergens including pollen and mold, helping you keep the air at home fresh, clean, and easy to breathe. It is washable too, so it needs fewer replacements.
Pollen
Mould
Filtering effect
Roborock S6 robots captures up to 96% of allergens including pollen and mold
S6 Exclusives
Tough but gentle
A brand new cleaning brush has boosted bristle density by 250%4. And the bristles are softer too. Even when spinning at 1350rpm it is soft on your floors but hard on dust.
More dense and soft
Roborock S6 new cleaning brush is soft on floors but hard on dust
Whisper quiet
Clean up whenever you need to. Advanced sound suppression design3 means S6 is not only 50% quieter than the S5. It sounds better too. Turning the harshness typical vacuum noise into a softer sound that doesn’t intrude, even during late night cleaning.
Quieter
Roborock S6 advanced sound suppression design
Not just a vacuum
Just snap the mop unit on, adjust how much water you want to use, and your robot is transformed into a vacuum and mop combo for a deeper clean. Give your floors a brighter shine with S6 Pure’s ultra-large 180ml water tank. Able to mop up to 150sqm (1610sqft)2 you can clean your entire home in one single run.
Roborock S6 Pure 180ml water tank
  180 ml
S6 Pure
Roborock S6 140ml water tank
  140 ml
S6
Roborock S6 Pure
Roborock S6 Pure
  • 180ml water tank
  • Standard Roborock bristles
Roborock S6
Roborock S6
  • Advanced sound suppression design
  • Ultra-fine DuPont bristles
1. Map Saving Mode must be switched on
2. Based on internal testing with low water flow. Actual results may vary. Range is an estimate based on an assumption that 20% of the area is covered by furniture and will not need mopping.
3. Produced and tested by an independent third party in accordance with EN 1822-1:2009 standards
4. Compared with the Roborock S5
5. Based on internal testing carried out by the manufacturer in Quiet mode on hard floors with a full battery and with no mop system attached. Actual results may vary according to the home environment.
Your coupon code:
ROBOROCKS
Copy Code
