New Arrivals: Purchase the S8 MaxV Ultra and Enjoy a Free 5-Year Warranty. Learn More
Roborock Qrevo MaxV
Get Closer, Clean Deeper
Introducing the Roborock Qrevo MaxV, where powerful cleaning meets advanced intelligence. Say "Hello Rocky" for an interactive cleaning experience that reaches every edge, navigates obstacles effortlessly, and keeps your floors squeaky clean with dynamic hot water re-washing and re-mopping.
Roborock Qrevo MaxV with Refill and Drainage System
On top of the maintenance-free dock features of the Roborock Qrevo MaxV, we've introduced a refill and drainage variant, taking your hands-free cleaning even further.
Auto Water Refill and Drain
Auto Detergent Dispenser
550 ml
Detergent Tank Size
Compact Design
Flawless Cleaning Reach
FlexiArm Design™ mop eliminates blind spots for an effective clean. It helps achieve flawless corners and edges effortlessly as the robot extends its mop, ensuring a 98.8% edge coverage with a precision margin of 1.85mm1.
98.8%
Edge Coverage
1.85 mm
Along the Edge
Cleaning along the walls
Cleaning near the dock
HyperForce® Cleaning Power
No Dirt or Dust Left Behind
Harness the unstoppable 7000 Pa HyperForce® suction power, combined with an all-rubber brush and dual spinning mops, to effortlessly remove debris, dirt, and stains from various floor types, leaving you with spotless floors.
7,000 Pa
Extreme Suction2
All-Rubber
Main Brush
30 Levels
Water Flow Options
200 RPM
Spinning Speed3
Liftable Brush and Mops
Elevate Your Cleaning Experience
The brush and mops automatically adjust for various cleaning tasks, maximizing effectiveness while preventing post-cleanup stains.
Vacuum-only Mop-only Carpet Cleaning Returning to Dock Mop Drying
Mops Lifted
Brush Lifted
Brush Lifted Mops Lifted
Vacuum-only
Mop-only
Carpet Cleaning
Returning to Dock
Mop Drying
Multifunctional Dock 2.0
Auto Tank Refilling
Hot Water Mop Washing
Warm Air Drying
Intelligent Dirt Detection
Check Your Environment
550 ml
Detergent Tank Size
Compact Design
Strong Wi-Fi coverage
Installation Requirements
140℉ hot water effectively removes stubborn stains and other dirt, saving time and water, while also disinfecting, to ensure that the mops are clean for an improved mopping experience.
99.7%
Bacteria Removal Rate5
140℉
Re-Wash
Re-Mop
Warm Air Drying
Dries the mops and dock base completely with 113℉ of warm air, preventing the growth of mold and unpleasant odors.
Auto Tank Refilling
Detachable Base
"Hello Rocky"
Just Say the Magic Word
Easily start cleanups by saying “Hello Rocky”, even without a WiFi connection. Whether you're busy cooking, tending to kids, or simply unwinding, cleaning has never been simpler.
Start cleaning
Clean here
Clean the bedroom
* The commands shown on this page are used as examples only. The actual performance may vary with use conditions.
Start and Pause Cleaning
Cleanups by Call
Specify Room Cleaning
Adjust Cleaning Modes
Mop Washing and Drying
* "Hello Rocky" intelligent voice assistant is available in selected languages, please refer to the Roborock app for more information.
Cleaning Access,
Always Within Reach
Third-Party Voice Control
Launcher Widgets
Apple Watch App
See It, Avoid It
Utilizing structured light and an RGB camera, Roborock Qrevo MaxV swiftly recognizes and evades 62 types of objects across 20 categories7, ensuring smooth cleaning without the need to pick up items, in both well-lit and dim environments.
62 types
Objects Recognizable
Automatic Room Recognition
Customized Cleaning, Courtesy of AI
The robot can recognize room and floor types to recommend suitable cleaning solutions.
Bedroom
Dining room
Living room
Bedroom
Dining room
Living room
Pawsome Features for Pet-Friendly Homes
Bells and Whistles
That Are Pet-Approved
Bells and Whistles That Are Pet-Approved
Video Call
Automatic Pet
Recognition
When approaching pets, the robot vacuum will immediately stop its main brush, and move aside in advance to prevent frightening your beloved pets.
Automatic Pet
Recognition
PreciSense® LiDAR Navigation
Precise Routes for
Precise Cleaning
6x Faster
Quick Mapping8
3D
Map Display
Multi-level
Mapping System9
Temporary Cleaning
Allows the robot to promptly deal with unexpected spills or messes without disrupting regular cleaning routine. Alternatively, enables it to temporarily skip cleaning specific areas where necessary.
Fast Cleaning
Custom Cleaning Routines
Supercharged Cleaning Performance
For Carpets
Thorough carpet cleaning without wetting the carpet.
Vacuum Carpet First
Deep Carpet Cleaning
For Carpets
For Hardwood Floors
Roborock Qrevo MaxV vacuums the floor along its direction so that the floor seams can be cleaned while minimizing scraping against them.
  • Customizable App Features
  • ScratchSafe® Wheels and Brush
  • Sensient® Sensor Array
  • Adaptive Route Algorithms
  • Child Lock
  • Off-Peak Charging
350 * 353 * 102 mm
340 * 487 * 521 mm
Q-Revo-MaxV
Roborock Qrevo MaxV
  • FlexiArm Design™ Edge Mopping System
  • Hot Water Mop Washing
  • Intelligent Dirt Detection
  • Intelligent Voice Assistant
  • Reactive AI Obstacle Recognition
  • 7,000 Pa HyperForce® Suction
  • Auto Brush and Mop Lifting
Q-Revo
Roborock Qrevo
  • Room Temp Water Mop Washing
  • 5,500 Pa HyperForce® Suction
  • Auto Mop Lifting
7. Based on internal testing carried out by the manufacturer, Roborock Qrevo MaxV can see and bypass objects down to as small as 5cm wide, and 3cm tall. Recognition accuracy may vary depending on environmental factors.
8. Compared to Clean&Mapping mode. Actual results may vary according to the home environment.
9. Up to four floors supported.
** During a transitional period, Roborock Qrevo MaxV may be depicted as Roborock Roborock Qrevo MaxV in certain channels.
Your coupon code:
ROBOROCKS
Copy Code
