New Arrivals: Purchase the S8 MaxV Ultra and Enjoy a Free 5-Year Warranty. Learn More
Series
Play Video
Join the cleaning revolution and experience effortless cleanups with the all-new DuoRoller™ Brush. Achieve total dirt and dust removal with the impressive 5,500 Pa suction and smart navigation powered by the Reactive Tech obstacle avoidance system. Cleaning has never been easier.
2x
All-Rubber Brushes
20%
Hair Pick-up Rate1
Double Rollers for
Double the Power
Introducing the DuoRoller™ Brush, the latest in Roborock’s cleaning technology, designed to enhance vacuuming performance on carpets, ensuring fewer hair tangles, and providing a hassle-free cleaning experience.
2x
All-Rubber Brushes
20%
Hair Pick-up Rate1
Impressive 5,500 Pa
Suction Power
HyperForce® suction power has been upgraded to 5,500 Pa2, allowing Q8 Max to easily remove dirt and pet hair from different types of floors, leaving you with a spotless living space every time.
Seamless Floor Cleaning
Remove Dust You Hardly See
30 Levels
Water Flow Options
Detachable Design
for Versatile Cleaning Needs
PreciSense® LiDAR Navigation creates detailed and accurate maps, enabling the Q8 Max to identify the most efficient route to navigate and optimally clean your home.
  • 6x Faster
    Quick Mapping3
  • 3D
    Map Display
  • Multi-level
    Mapping System4
Clean As You Wish
Custom Cleaning Routine
Fast Cleaning
Clean On and On
240 min
Maximum Runtime6
300 sqm (3230 sqft)
Maximum Vacuuming Area6
Speak to Command
Handles Your
Dirty Work
7 Weeks
*RockDock® Plus is only available with the Roborock Q8 Max+.
  • Customizable App Features
  • Sensient® Sensor Array
  • Adaptive Route Algorithms
  • Child Lock
  • Off-Peak Charging
Q8 Max Dimensions
Robot vacuum
350*353*96.5 mm
305*440*448 mm
Q8 Max+
  • Auto Dust Emptying
  • DuoRoller™ Brush
  • 5,500 Pa Suction
Q7 Max+
  • Single All-Rubber Brush
  • 4,200 Pa Suction
Your coupon code:
ROBOROCKS
Copy Code
